2020 2500 Custom with remote start.  If I’m looking to add heated steering wheel, do I have the harness under the dash or within the column?  Is there even a harness on the dash side for steering wheel audio controls with the small WT/Custom trim radio?  I’ll just stick with the heated steering wheel controls if no radio harness, but thought I’d ask if anyone knows.  And, is anyone else looking to do this?  I can work in the wind, cold, rain, no problem but once I get in my rig sure does feel good to warm up.  A heated wheel would be nice in the morning for the old paws.
Been looking at videos from prior body style that do this (below).  If there are pictures of where I would look to confirm, or part numbers for what I’d need that would help.  I’ll accumulate parts as I can and pull the trigger when I have everything.
Side note, all the www parts places, i.e. GM Parts Direct, gmpartsonline, etc.  They’ll all let you select 2020 2500 and even now 2021 2500 although the images are clearly from the prior body style.  When I am able to crosswalk NBS part numbers from random posts and other projects, they are on pages in these parts sites that you can’t get to from the lookup - and are different than what the selection tree gets you to from choosing 2020 2500, etc.  Hopefully they’ll start to update and locate/display the new body style soon.
Parts I think I’d need:
1.       Leather heated steering wheel
2.       Left steering wheel side controls with the heated steering wheel option.
a.       Comes with steering wheel side harness?  Not sure, but I think that is separate.
3.       Clock spring having correct options
4.       Remote start?  This was a consideration in the videos, looking at prior body style parts on websites looks like remote start had something in either the wheel or the clock spring.
Even if I don’t have the dash side harness, seems like I could add it, Right?  If that’s the case, any info on part numbers for that too?  Also kind of wondering if there are any other GM wheels that would work.  if I'm going to have to locate a new wheel, maybe I can go smaller or more sport'ish, like Camaro or something?
i do not believe you can as there is no harness to connect too.....seen a few threads posted about this already  for 1500s and 2500s (?) but i believe it was for both....2021 maybe different and  i could be wrong but something tells me i looked into this b4 i bought my 2500, and swayed me to what i have......i do know there has been a few threads and should be easy to find though
Thanks.  Well, that sucks.  Or, just makes it harder.  I'll keep digging around to understand if I can find the dash-side harness separately, etc.
  • 4 months later...
NW Silverado have you had any luck with this install? I have ordered the wheel and clock spring but was curios as to any additional parts?
Wish I have, but no definitive info. I haven’t pulled my steering wheel to see if the truck-side harness or plugs even work with a heated wheel. If you do it let us know!
They don’t work. From the digging I did a few months ago it is possible to add but will require a new dash harness, gauge cluster, stereo head unit, clock spring and the steering wheel. After you’ve swapped everything over the dealer will need to reprogram the bcm.
lots have tried on 1500s with no luck is only reason i know about it.....
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,299 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
