When I purchased my 2020 2500 Denali the sales guy said "and it has adaptive cruise control" which sealed the deal. It might not seem like a big deal but I bought the truck to tow my 30' travel trailer and using cruise control on long trips is a must. Having adaptive cruise would be amazing! I took the truck back to the dealer and told them its not working. They fiddled around for a few a minuets and said I would have to schedule an appointment to have it looked at. Come to find out the dam thing doesn't have that feature.... I assume GM feels that it's a bad idea to allow people towing to rely on adaptive. The logic doesn't work for me.
I have to assume that all of the hardware is in the truck but the feature is looked out in software.   So the question is can I have the feature activated?
Edited by Foldbak
If u figure it out let us know
would think if u have front collision alert it should be somewhat doable but not sure what programming u could use since it's not event a option on the fully loaded trucks
Sent from my Moto Z (2) using Tapatalk
It's not likely that the feature can be activated even if it is in the software. GM has gone to great lengths to encrypt the systems so that they cannot be tampered with. Everything I've read to date says the system cannot be penetrated.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,270 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
