I was looking at the Airdog systems and watched some YouTube videos on their claims of added MPG and HP. Does anyone on here have the Airdog that they had installed on their truck. A supervisor of mine has it on a truck he just bought, but it was there when he bought it so he cant really tell me if it made a difference. Also why is 2015-2016 the last model years they have these available for?
Well I sent them and email and got an almost instant response;
"At this time we are not trying to develop a kit for the l5p. The reasoning for that is they do now come with a factory in tank pump that would have to be removed to use our system. To remove the factory pump and clear any trouble codes it would require tuning, and with how things are starting to shift we at this time do not want to offer any kits that require tuning."
Well there you have it I guess.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
