Please help. I am installing accent lights on the exterior and interior of my truck. Does anyone know how I can wire them to turn on when the doors open on my 2020 silverado 2500HD?
Just a matter of finding the dome light wire. Hopefully someone can point us in the right direction
Edited by motorsswin
you'd need to find the "door trigger" wire, or utilize the Dome Light wire.  I found this online for a 2019, may be the same.  Depending on the lights you are doing you may need to add in a relay to carry the amperage your lights may require.
Left Front Door Trigger     Gray or Pink (power window)     -     Driver Door Latch, green 10 pin plug, pin 1
Left Front Door Trigger 2     Gray (manual window)     -     BCM under driver dash, gray 26 pin plug, pin 25
Right Front Door Trigger     Gray (power window)     -     Passenger Door Latch, green 10 pin plug, pin 5
Right Front Door Trigger 2     Gray (manual window)     -     BCM under driver dash, gray 26 pin plug, pin 14
Left Rear Door Trigger     Gray or Green     -     Left Rear Window Switch, black 10 pin plug, pin 2
Right Rear Door Trigger     Green     -     Right Rear Window Switch, black 10 pin plug, pin 2
Dome Light     Gray     +     BCM under driver dash, white 26 pin plug, pin 23
  • 4 months later...
Reviving the dead here as I am looking to add lights to shine on my running boards. I did this on my 2015 GMC sierra 1500 using the puddle lamp circuit on the BCM. Does anyone know which wire this would be on the 2500HD? Picture for reference.
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 481 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
