Hello...  2018 GMC Sierra 5.3L engine.
Today, while out on an appt, received an incoming phone call on the cab entertainment console.  Knowing it was scam number, I cancelled the call but then a strange alarm came thru at the same time that did not resolve.  The alarm would not subside.  I cut the engine and removed my key but the alarm continued.  Closed my door but still continued.  I then attempted to power off the console but now the sound system was frozen.  The alarm finally stopped but the radio was still frozen.  A couple more attempts to power the console off/on still had a frozen display.  I did get my preset stations but you could not navigate to any stations.  No sound to speakers.
I then took my truck to my GMC dealer where I then setup for an appt in a week.  Upon leaving the store, I started my truck and now the entertainment console was working just fine.  Placed a phone call with no problems.
Might GM be aware of this problem?  The service agent stated that the system may need a hard reset but that they could not handle today hence my appt.
[email protected]
Edited by NWS405
These radios are garbage. Gm's feeble attempt and something gd. Imo, they dropped the ball. The radio gets a glitch and locks up, had it happen a couple times.
Sent from my SM-G960U using Tapatalk
    rayredbone
    rayredbone
  • Who's Online   4 Members, 0 Anonymous, 483 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
