I have a 2018 Silverado 1500 High Country with the 6.2 engine.  Recently purchased a DiabloSports Predator 2 tuner, which to my dismay, does not have anything for the 8L90 transmission.  Does anyone know why?
As far as I know there is no tuning available for the eight speed.
Sent from my Pixel 3 using Tapatalk
The TCM's are "locked" and none of the handheld tuners can do anything with them.
HP Tuners is the only way to tune the 8 speeds on 2017-2018 trucks. You'd have to send in your TCM to HP Tuners, pay the unlock fee and then pay the fee to license that TCM with HP Tuners. To fully tune a truck like yours would cost about $900 I believe. HP Tuners is $300, plus $200 for the PCM unlock, plus $~200 for the TCM unlock and $200 more for the TCM license. Then you have to learn how to tune it youself and your truck will be down for a few a week with the TCM unlock service.
Thanks CamGTP.  For that kind of money, I am beginning to believe the trans shifts just fine the way it is.  I wasn't thrilled the way Diablo Sports sells the Predator Tuner.  They never mention the additional $40 for the GM unlock feature nor do they say anything about the inability to do anything with the transmission.
Truck won't be down a few weeks.  1-3 business days if you send them yours + shipping, which is $199.  Or send them another TCM and they will program it for you for $299 then you just swap TCM's and have zero down time.
It would be $900 all in, plus $250 if you go with the Pro Feature set (useful for adding wideband logging).
In 2 years when my warranty is up, I'll be doing this on my truck for E85 tuning and a little other stuff.  Currently buying it + wideband for my car now to retune the hack job a "pro" tuner did on the car by the previous owner.
They sell a AEM can-bus wideband, I use one. Saves you $250 so you don't need the wideband plus the pro feature set.
Edited by CamGTP
    • If it has a stick I can have fun with it. When my wife first got her Acura years ago I used to tease her about it. I was only interested in muscle cars. They’re gone now. So once a month I drive the Acura. Every once in a while I’ll take it to Redline. But just normal driving on some twisty back roads usually does the trick.
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
