I have a 2018 Silverado 1500 High Country with the 6.2 engine.  Recently purchased a DiabloSports Predator 2 tuner, which to my dismay, does not have anything for the 8L90 transmission.  Does anyone know why?
As far as I know there is no tuning available for the eight speed.
Sent from my Pixel 3 using Tapatalk
The TCM's are "locked" and none of the handheld tuners can do anything with them.
HP Tuners is the only way to tune the 8 speeds on 2017-2018 trucks. You'd have to send in your TCM to HP Tuners, pay the unlock fee and then pay the fee to license that TCM with HP Tuners. To fully tune a truck like yours would cost about $900 I believe. HP Tuners is $300, plus $200 for the PCM unlock, plus $~200 for the TCM unlock and $200 more for the TCM license. Then you have to learn how to tune it youself and your truck will be down for a few a week with the TCM unlock service.
Thanks CamGTP.  For that kind of money, I am beginning to believe the trans shifts just fine the way it is.  I wasn't thrilled the way Diablo Sports sells the Predator Tuner.  They never mention the additional $40 for the GM unlock feature nor do they say anything about the inability to do anything with the transmission.
Truck won't be down a few weeks.  1-3 business days if you send them yours + shipping, which is $199.  Or send them another TCM and they will program it for you for $299 then you just swap TCM's and have zero down time.
It would be $900 all in, plus $250 if you go with the Pro Feature set (useful for adding wideband logging).
In 2 years when my warranty is up, I'll be doing this on my truck for E85 tuning and a little other stuff.  Currently buying it + wideband for my car now to retune the hack job a "pro" tuner did on the car by the previous owner.
They sell a AEM can-bus wideband, I use one. Saves you $250 so you don't need the wideband plus the pro feature set.
Edited by CamGTP
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
