Hey everyone. Sorry if this has been covered before but for some reason I can't do a search in the forums. I have a 2015 Sierra 5.3 with 132K kms. I have had a Range disabler and Magnaflow cat-back pretty much all along, and about 10K kms ago I installed an HPS intake. A couple weeks ago when climbing a hill on the highway at about 3.5K rpms the truck stopped pulling but continued revving and the exhaust changed to a high pitched sound. I backed off and it seemed to catch it's breath but it didn't run right the rest of the week. On that Friday about a mile from my house I stepped on it again and up around 3.5K it did it again and this time it caused damage. #7 cylinder has only 30psi compression and the shop says the cylinder walls are scored and the piston is damaged. They didn't mention any damage to the head. I have not seen the pictures yet and they haven't told me yet what they think happened other than there was oil and coolant on the piston. I'm sure the coolant was spillage from pulling the head. The only code showing was P0307. There was no audible tapping or knocking sound but the exhaust sounds hollow and garbled when idling and had a really bad sour smell when driving up on the flat bed. Maybe a ring land failure from detonation?  If it was detonation could the aftermarket intake have possibly anything to do with it? TIA for any opinions.
Edited by Slickracer34
The intake won't have anything to do with what may have happened.
Sounds like bad luck and something let go. I would only be guessing at the cause from where I sit as well. Could be a ring failure that scored the wall, injector issue that lead to it or who knows what else.
Yeah I didn't think so either. If the intake was the issue I should have got a code for lean condition or something. It never threw a code until it was in my driveway puking 10 mins after it let go. On a side note the oil pump grenaded at 15K kms and they didn't replace the motor. It got flushed and they said it was fine and everybody I knew said they should have replaced it. I said if that oil pump failure did any damage it'll show before my warranty is up. My warranty is up at 140K so I'm glad that whatever it was that happened it happened now.
It could have been detonation... and then a broken ring.If you catch it immediately - pull the piston and replace it - you can just have some marks in the cylinder. With a broken ring.. any period of time running it- that ring - the broken part that is a half circle sized or so - the ends will gouge the cyl wall.
When you pull the piston and see the ring - and the top ring - you can speculate detonation caused ring land / broken ring failure was the result....
i know this the hard way....
Edited by PPK
I just got my truck back today with the new motor. All the work order said is there was moisture in the exhaust manifold and past the valves. There was blow by and a hair line crack in the cylinder. I never did get to see the photos they took of the damage. I'm pretty sure whatever it was that happened wasn't caused by my cold air intake. There must be a thousand or more people running intakes on these motors with no issues whatsoever. The dealer said this is the first L83 they have ever seen this happen to. Was your detonation issue on your L83?
Detonation.. yes.. A Ford. broken ring lands - and rings. i think the piston broke first - and then the rings of course without support went. Detonation in a pre-90s Ford without the sensors and controls of fuel injected engines...
  • 2 months later...
Here's an update on my engine replacement. I'll never know what happened to the original motor since it's been shipped back. The dealer somehow lost all the photos of the damage and seem to dance around all my questions when I push them on it. Oh well at least I have a new motor and 2K kms of warranty left. The more I run it through my mind and remember what it sounded like when it happened I am positive it was detonation that killed it. I've only ever run 87 octane and two weeks ago I switched to 91. Since then my mileage has gone from 17-18L/100km to 13.5-15L/100km. I think that's about 14mpg to 17mpg but not sure. It runs better, idles smoother, and feels more responsive. I plan on putting the HPS intake back on when I put my summer wheels on and will be running 91 octane from now on. Just my two cents.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
