Grumpy Tooch Posted February 20, 2021 Posted February 20, 2021 Hello, I have posted this in this thread here but have not gotten any answers yet. I will assume its not being watched anymore, but i still would like some help if possible. I have done this successfuly 5 years ago when I got my truck, but only used AUX 1, AUX2, of the switch bank i installed. Now i want to utilize the last 2 AUX switches. The problem I have is that the switches are acting different tha n the other 2 i used, they have 12V+ initially and when the switch is depressed the power goes to zero. The other 2 switches are opposite this. It is the Exhaust brake switch on the end of the switch bank i am trying to use. If i set everything up same I have the problem of the light being on all time and not being able to be switched off. Not sure i can reverse the polarity on the exhaust brake harness since this is the only thing i am using it for, but it may affect the indicator light feed which is working fine. I am hoping to come up with a solution where i can maybe do something to the board with the latching relays or the feed from the switch which is 12v+, i need tis to be nothing when in relaxed position and 12v+ when pushed to turn on the latching relay. I hope this makes sense and i can get some insight from you guys. Thank you
Register a new accountSign in
