I have 2019 CC Standard Bed GMC Sierra 5.3 4WD.  Either my tank isn't getting full, my gauge isn't working or my tank is not the 24 gallons spec'd for my truck.  When on empty (fuel light on and miles to empty showing low), it only took 20.5 gallons of gas.  I filled it till the pump shut off, but the gauge is showing slightly below full. This has happened at 4 different gas stations (2 Costcos, 1 Shell and 1 Fast Trip).
Has anyone else had this issue?  I am still under warranty, but I was hoping to have an Idea of the issue before I went back to the dealer.
Set one of the trip meters when you fill up.
Next fill, use the trip MPG and the miles driven and see if that matches the gallons pumped.
FWIW, mine the 'low fuel' light seems to come on somewhere around 60 miles range.
Range screen changes to 'low' somewhere around 50 miles.
Range estimate depends on the 'recent' fuel economy it's been getting (last 25??).
Imo, they are trying to reduce they chances that someone has to walk...(I can imagine the uproar if 'they' don't warn us soon enough!!)
Imo, it's good to know 'about' how much fuel is left when the warnings start.
if you subscribe to onstar you can hit vehicle status on mygmc and it will give you the actual percentage. Take some screen captures, collect your gas receipt and take to the dealer.
My 2019 Silverado had the same issue - dealer replaced the electronic fuel level sensor, and that solved it.
You may have a slightly faulty sensor, but I've always understood that when the low fuel light comes on you have about 10% left in the tank which would be about 2.5 gallons and in most vehicles. That would get you about 30 to 60 miles before you completely run out of fuel.
I've tested this on past vehicles by carrying a 5 gallon gas can and running until empty to see how far I could go after the low fuel light came on.
My 2003 Hemi went over 60 miles before it quit. I had the 26 gallon tank.
I was getting about 22-25 mpg so that seemed close enough.
Word of warning: You don't want to do this too many times as the electronic fuel pump in the tank relies on the fuel to keep it cool.
Once is enough.
When filling at a station, I will allow the hose to shut off and wait about a minute ( or wash the windows.) and run it again until it shuts off once more. Gains another 1/2 to a 1 gallon in my 2020 Silverado 3.0 Duramax.
Fuel pump thing may have been an issue when first used to replace the mechanical ones, but I don't think it is anymore (at least for GM pickups).
I've been a frequent user of the 'low fuel' light for at least the last 15 years.
(nope, never had to walk or send for fuel)
Sorry, I guess I didn't make myself clear.
The "fuel pump thing" you talk about is when you "run out of fuel".
Not when the low fuel warning light comes on.
I guarantee you the fuel pump in the tank will get hot and burn out if you run out of fuel too often. The fuel is used to cool the pump.
I worked for 31 years at AC Delco and many of those were in the electric fuel pump division.
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
