little plates behind door handle that covers the screws, tabs are super weak and busted a few tabs off.......checked gm parts now, parts direct, and cant seen to find them......am sure even a silverado wil fit......to the peeps in the know where the best place to get parts for trucks.......also wouldnt mind getting a bag of thos clips they use to secure door panels on....the white male and female plastic ones with rubber grommet......if anyone knows i would appreciate it to find them asap.......thanks
thanks....think i found it was bit frustrating at first
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
