To start, there are more dash camera options available today then there are automotive manufactures. everyone has their own flavor and key requirements for what they need.
I've had a couple people ask questions about what setup I'm using, how dependable it is in Oklahoma heat, what the cost totals, and what the maintenance totals.
I have the same camera in each of my vehicles. The following list will help for some.
AUKEY dash camera front and rear... and use the same model in all my cars.
link to it on amazon $130
https://www.amazon.com/gp/product/B075S7W6FR/ref=ox_sc_saved_title_9?smid=A1GB2I3NQT9NQC&psc=1
I have the cable under the headliner and down the A pillar on the passengers side, before feeding the cable behind the bottom edge of the dash and routing the cable to the glovebox USB.
I would recommend getting a 90 degree connector, as the cable that comes with the camera will get a little "kinked" when closing the glove box otherwise.
link to the 90 deg cable connection $7
https://www.amazon.com/gp/product/B084WPG7QG/ref=ppx_yo_dt_b_asin_image_o00_s00?ie=UTF8&psc=1
Front camera WILL need a filter. The viofo clips onto the AUKEY perfectly!
link to the filter on amazon $15
https://www.amazon.com/gp/product/B01N0KVD4C/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Standard memory cards will last one summer parked outside.
"High Endurance" cards will get a couple of years.
link to the card on amazon $22
https://www.amazon.com/SanDisk-Endurance-microSDXC-Adapter-Monitoring/dp/B07NY23WBG/ref=pd_bxgy_img_2/140-3681450-1512527?_encoding=UTF8&pd_rd_i=B07NY23WBG&pd_rd_r=93c2560a-c581-4313-9e83-56afe89b7352&pd_rd_w=u067F&pd_rd_wg=1uIsf&pf_rd_p=f325d01c-4658-4593-be83-3e12ca663f0e&pf_rd_r=NX8GAGXT7P71EWQHXYJR&psc=1&refRID=NX8GAGXT7P71EWQHXYJR
TOTAL $175
*add in some tax and it's close to 200
The attached images show the cameras, front and rear, installed in my sierra. Out of sight, out of mind!
The camera will make a chirp and whoosh sound when it boots.
Link to videos from the camera.
Front camera
Rear camera
in the last 3 years these cameras have saved 10 times what ive paid for them in different events that have happened. *"they rear ended me officer!" and then i share the footage that shows they backed into me*
good investment
15 minutes ago, NE18 said:
anyway to not record audio from inside the cab?
Don't want people to hear you rockin out to Justin Bieber?
  • Haha 1
BINGO. 😂
yes. setting in the options for audio. just a simple on or off.
NOTE:  I keep the audio on for the following....  not every pixel is as clear as what you see from the drivers seat. it's always a safe bet to say the license plate number on any car you have just been in an accident with! Wife had a hit-and-run and she had the license plate in a clear portion of the video from a few miles before the accident, but we are thankful there was also the audio of her saying the plate number.
otherwise, dont be shy to belt out your best "baby baby baby...."
Thanks for sharing. I'm curious about whether that USB port has a setting where you can turn off the constant power. I noticed with a monster cables wireless charger Mount combo, that the power stayed active with the truck off.  Do your cameras maintain power when you turn the truck off? I have a 2018 Silverado. Thanks!
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 463 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
