I have a 2018 Sierra Denali.  Does anyone know if there is a way to get the play out of the running boards when they are extended out.  The boards will move in and out about 1/4”.  If someone doesn’t pay attention they can slip stepping up because of the movement.  I was wondering if there is a tension adjustment or something to fix it.
Welcome to the site.
Have you checked your mounting brackets to make sure they are all tight?
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
