I have a 2014 Silverado and on the drivers side I get this squeak/chirp when I hit a bump or rut in the road.  It sounds like it is coming from the inside, under the dash area of the drivers side.  It does not matter if I am turning or driving straight.  Its seems like it happens more when I am going slow but I will get it on the freeway if there are bumps, but less so since most of the freeways are smooth.
I live in the midwest and after the winter if I gotdown a bad road, cracks, whole, bumps it can really do it a lot.
Any suggestions?
Thanks!
Check the screws behind the the panel under the steering wheel. Remove the panel and there's 4 screws behind there. They are usually loose. That's where I would start. Hope that helps.
Sent from my SM-N975U using Tapatalk
This.
When I installed my new Denali cluster, those bolts were way loose!
