Hey guys I need some help. I have a 97 Silverado 5.7 4l60e that when I put the truck into park I hear a grinding noise that I can’t quite pin point. Note the drive shaft is not in the truck and this is happening while sitting in one spot. Also I put the truck in drive and revved the engine and there was the same grinding noise. Does anyone have a possible area to look.
your transmission isnt going into park , how oid is your trans. might be time for rebuilt or replacement, its not going to get better , only worse
Re-install the driveshaft and try again,I'll bet the tailshaft is spinning and not letting the parking pawl engage.
    jrogjr
    jrogjr
  • Who's Online   4 Members, 0 Anonymous, 274 Guests (See full list)
    • Average Assembly 4.8%   That's the likelihood of a light duty vehicle reaching 250,000 miles. Link below has the stats on this. Among pickups the 350 series (Dodge)  and higher (450 Ford) are most likely and nothing American built in the lighter trucks pegs a number higher than the overall average.  200K and up is the stomping grounds of Asian vehicles. Toyota Sequoia the leader at 39.1% probability.      https://www.autoweek.com/news/a68886903/vehicles-most-likely-to-last-over-250000-miles/   Likelihood drops dramatically at 100,000 miles of reaching even 150,000 miles. 250,000 is deep in the tail of the curve.    I've been told by the 'experts' that I don't need oils of the caliber I use. My high viscosity is damaging my motors. Ash content it to high and WILL foul plugs and kill cats and O2's. I don't need that much ZDP; my choice is over added and not cutting edge. I change it to often. I baby them to much.    Three Honda's reached 200K + and none used oil. All Red Line motors. All sold to friends or family. One Toyota reached 300K using oil, Pennzoil. Dizzy 300K using QSUD until it cashed the rings at 80K then whatever but often ever since. Did you know this engine still sports the OEM timing chain and is dead silent? Pepper spitting into the wind short of 200K, Red Line and changed often. Uses zero oil. A HPFP and a pinion seal. Still using most parts it left Fort Wayne with. So 50% of my vehicles have gone past 250K and 100% of the last half dozen past 200K. Of these two using "shelf oils' did so using abnormal oil and the four that used a premium boutique oil did not. There might be something there the experts have missed. 🤔
    • i dont know where you been reading...they make a top notch product..people say lots of great things about them..yes it can be difficult to get a hold of them when you need help sometimes put when  you do it is great service...   as for the actual question at hand i have the ccv mod and i vented to atmos in my case...I got my ccv from somewhere else but i have plenty of VSE product...for starters i use their tuning on my 22 duramax
    • It's not that it sits for extended periods. I drive it every couple of weeks. However, I did consider draining the DEF and replacing it.    Don't you get a "Poor quality DEF warning" if its bad?
    • Try draining the def and relacing with new if it has been sitting for a long time. Def does go bad after a little while.
    • Thanks @Viktorrocks15 if you are still out there.   I followed your instructions and worked out great, went to the scrap yard and procured 2016 escalade cluster, hud, bezel, and switch. Got lucky and found a Camaro in the u-pull with the HUD bezel.   I made my own harness with these diagrams: https://www.gmupfitter.com/wp-content/uploads/2022/10/23_Escalade_Escalade_ESV_Electrical_Body_Builder_SM_en_US_2022OCT25.pdf   I used escalade cluster because its the best one that will work IMO. Still need to get it programmed but it looks really good.
