Another parking sensor post: I have been battling parking sensor issue for 1.5 years now. I get a ghost false signal when stopping and going 50% of the time. I’ve been to the dealer 4 times and they have replaced the front center sensors multiple times and reprogrammed the module. Still have the problem.
Has anyone else had these problems and found that one ah-ha thing that fixed it? Because I feel the dealer is simply doing the same thing over and over again. It’s f*#%ing annoying. I don’t even think I’d be able to sell it with this issue.
I have an autocal tuner, does anyone program them to be permanently disabled or default disabled using a tuner?
I get false signals occasionally and just hit the off when it happens.  Annoying, but not the end of the world.
They've replaced the sensors, but not the harnesses in the bumper?  I'd be suspect of a faulty wiring harness so something like a wire in there or fretting (electrical corrosion) or actual corrosion on the terminals in the plugs.  Could be in the plugs to the sensors but the connection point I'd be interested in looking at is where the harness plugs into the body side of things.
The main 16 way connector for the harness into the chassis harness should be center driver's side of the bumper.  If one of the sensor plugs is junk, or you need the main plug, you have to get the whole harness.  P/N 23261390 for 2014-2015, 2016-2018 its 23274031.
If the 16 way on the chassis side is bad, they sell a pigtail for it.  2014-2015 use 19259857, 2016-2018 use 19354087.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
    • Open the driver's door jamb.  What do the cold tire PSI ratings on the tire placard show?   I'm not saying to run it to those numbers, but I would like to know what it says.
