Lost power to both taillights. where does the power source come from to run tail lights ?  Dont seem to have power at the junction block . Any help is appreciated  Thank you
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
