This ring is supposed to be connected to my drive shift where it meets the rear differential/ transfer case. It’s come off and some parts are missing. Getting the trucked towed to the dealership now.
What is this part called? Anyone have a part number?7458240a9ceed30b8c5108265885f88c.jpg
i think it is just a vibration dampener.
I have seen a couple of these fail.
I don't know why it is even needed. if the driveshaft is balanced, I don't know if it is necessary
  • 5 months later...
I just had the same thing fail over the weekend.  Did you ever find the right part name and what was the fix for this?  I figure it came off from the front of the drive shaft, but I couldn't figure out how it was attached to begin with.  Was there some sort of retainer that broke away?
Thank you,
Laurent
If they have a vibration damper at that location it’s likely for torsional vibration, not unbalance.
  • 3 months later...
We had this happen to our 1-Ton at work.  It was driven over a stump and the stump knocked it off.  We ordered a new one from GM, but in the mean time we just took the driveshaft loose at the rear and slide it off.  We've put probably 20k on the truck without it on there and it's fine.  It used to be mounted directly in front of where it is now on that round circle flange.  It's help on with rubber bushings.  Our new one is still sitting in the box.
It's for torsional vibration -- to make the driveline components last longer.
Same thing as the harmonic balancer on the front of the crank.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
