I am looking for a tonneau cover for an AT4 HD that I ordered.  I would like a hard cover, but I can not device between a hard trifold, or a hard roll-up.  If I get a trifold I want it to fold all the way up against the window so that I have access to the entire bed if I need it.  Are the hard roll-up ones secure?  I will not be storing stuff in the bed, but if I put some luggage in the bed and stop to eat lunch somewhere will it be secure?  Any brands to stay away from?
So just went through this and ended up with a roll up, soft cover.  Trifolds from what I saw wont fold all the way up,  there will always be that last 1-2ft sticking out.
As for security once you lock the tail gate there really is no way to get into those unless you get the toolbox friendly ones that open both ways.  Now were talking vinyl so anybody with a utility knife can get into those things.  But with any sort of lock it keeps the honest honest and stops 80% of those out there.  I would think in general the trifold would be more secure than the roll up due to how secures.
For me I went with the roll up this time around and heres why. Always had a tri fold and in general I liked them.  My only issue is when I need the whole bed for something,  it was easy enough to take off but if I forgot to leave it home its one more thing to get in the way, take up space, and to secure with a load.  Roll ups go all the way to the window and should help this out.
Im not the guy that spends thousands on these things as they all kind of work the same, and I dont keep trucks long.
I went hard roll up.  Liked that it was flush with the bed.  Thing that you may like better about the tri-fold is that with that you may be able to leave partially open.  The roll up they recommend you roll all the way up and secure every time.
I almost went this route but in upstate NY was concerned with the snow and ice
Have you had any issues with it?  I was looking at reviews and they had a decent number of bad reviews.  Does it seem like it could support weight on it.  For example like 5 inches of snow?  Thanks for the picture!
I have found a few that fold all the way up.  You can have access to the whole bed, but the window is blocked.  I also would like to use the whole bed and am looking to not pay too much.  Thanks
I live in New England, no issues at all.  It is actually really sturdy, plus I wouldn't let snow sit on it for too long since it wipes right off.  Price was good since I bought thru Chevy.com Accessories site and used my Chevy Legends 20% off discount.
I have an Undercover Flex hard cover. When folded up it doesn't sit against back of cab or window. It stands up using prop rods. Only takes up about six inches or so of bed. So far it has been water tight even when using the carwash. Plus When tail gate is closed and locked a person cannot get in.
I have the BakFlip F1 cover.  It is a fold-up and opens all the way back to the rear window.  Like @jscottl above - the last fold is secured by prop rods.
I tried the roll-up covers in the past and decided to go with a folding cover this time around.
    DM22
    DM22
  • Who's Online   0 Members, 0 Anonymous, 2,351 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
