Hello Everyone,
I'm helping a friend with his truck, 2004 GMC Sierra 1500 SLE 5.3L. Removed and replaced forgive me if the name is incorrect the I/P Harness that runs from the Fuse Block under the hood ,through the firewall, and  runs along the dash. Got it out with a struggle, install went smooth until the reason I'm asking for help. I have a connector that I can not figure out where it belongs???  It's a grey with  8 cavities with 1 Black with White stripe (Ground), 1 Brown, and 2 Brown with White Stripe wires. It exits the harness where the headlight dimming switch connector does. If anyone can help me or if you need more information please let me know. Thank you in advance for your time.
So I did look to see if I could locate that harness connection and just cant seem to find it on my 04 gmc sierra. I do know, that black w/ white tracer can be linked to the multifunction switch, brakes, Hvac, and RAF.  I am assuming you removed the old harness because the truck caught fire, or had serious damage.  How sure are you that you got the exact same harness from a sierra 04?  I can give you a link to every wiring diagram for your truck, but there is a lot of information, and it will take time to work through.  There is a limited amount of spots this connection can go, have you put juice to the truck yet to see if it would crank/code?
On 4/28/2021 at 12:43 AM, Tyler Porter said:
Hello Everyone,
Does it go to a rear cargo lamp button I have an 04 chevy and there is a plug with the headlight switch that goes to a push button right next to the head light switch that runs the cargo lamp and I do rember the plug looked the same as that one I would have to pop the button back out to see If the colors are the same but If I rember correctly they are
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
