**** SOLVED! I'll post pictures after I finish for anyone who wants to see how it's set up!
Edited by prox_denali
  • 3 weeks later...
Alright so after months of seemingly endless videos and pictures of people's catch can installs, I sacked up and bought a Motion Raceworks catch can. While the price difference compared to other cans is certainly one point that is not to be overlooked, I really could not be happier with the way it looks and the level of customer service that Motion Raceworks has. I gave them my year, make, model, and modifications done to the truck to figure out how it should be routed, they told me what I needed and sent everything to me in a matter of a few days. Upon attempting to install it (the first time... six months later) I realized that where I was attempting to run the lines to just simply would not work. - PCV Valve to catch can and intake manifold pcv port to catch can - The AN fittings were too large. According to Procharger's install instructions (without a catch can), they say to connect a 5/8" hose that loops the valve covers - then tee from the loop to another small 5/8" hose section that connects to a 90 degree fitting on the back of the filter for the Procharger. Thus, I was getting a fair amount of oil and etc. getting pushed right back through the Procharger and into the motor. Nonetheless, as you can see below, this is how I ran the catch can per the instructions given over the phone by both Motion Raceworks and Procharger.
I also included pictures to show the vacuum line from the intake manifold. Soon this will be rerouted (yet again) for another vacuum manifold so I can hook up my boost/vacuum gauge. Reason for this was that I must have bumped the previous vacuum line into the serpentine belt and it began cutting into the hose. Therefore it needed to be fixed in order to drive it.
According to both Motion Raceworks and Procharger during the catch can install, the PCV valve 'must be plugged'. You will see my attempt (or temporary solution) to plugging the valve below. I simply purchased a new PCV valve and kept the green cover on the port that came with the PCV valve. Do note, this is not an airtight seal. I am able to feel a very small amount of air moving from underneath the cover. It is likely that I will source a brass or aluminum plug to fit in place of where the PCV valve threads into the motor (I believe it's 5/8" but have yet to try with an actual fitting.) Before installing the catch can, I had the PCV valve just venting to the atmosphere with nothing connected to it and ran just fine despite continuing to see oil in my intake.
I then used a combination of 3/8" hose and 5/16" hose and 1/4" fittings to connect the intake manifold PCV port to the bypass valve. Procharger's install instructions say (without a catch can) to route a 3/8" hose from the PCV valve to a supplied vacuum manifold (that I lost when installing the cam) and the vacuum manifold is then routed to the pcv port on the intake manifold along with a 1/8" hose that is connected from the vacuum manifold to the bypass valve. Believe me if that sounds confusing, it looked just as confusing in the install instructions provided by Procharger.
Moral of the story is, Motion Raceworks catch can is designed to be connected to the ports on the valve covers. It was literally that simple.
Hopefully, if you are looking to install a Procharger or centrifugal supercharger and a catch can on your truck, that the pictures will help.
As far as installing the AN lines, I highly suggest purchasing aluminum blocks that fit into a vise and an adjustable AN wrench. I sourced them from Amazon. I marred up one of my fittings pretty good when I was attempting to use a normal adjustable wrench and resulted in me buying another $30 fitting to replace it. It was my first time messing with AN lines but now, I feel I want to replace everything I can with AN lines (I would if it weren't so gosh darn expensive!)
I know, I've been going on and on, so without further ado here are the pictures!
Engine Bay from Driver Side:
Yeah I know... it's a little dirty in there at the moment haha
10 AN lines along with rerouted/replumbed vacuum line
Driver side valve cover connection
Passenger side valve cover connection
PCV valve 'plug' and intake manifold PCV port
Rerouted/replumbed vacuum line from intake manifold to bypass valve.
The catch can itself
And just for the hell of it
Let me know what ya'll think!
Cheers,
Griff
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
