Hey guys- I have a 2 week old AT4 and I love it other than the fact it sounds like a marble or a screw or something rolling around when I take turns behind the gauges or possibly in/around the steering column. I tried to reach my arm up under from around the pedals but I can’t reach or feel anything that might be loose or rolling around. Anyone know of how to remove some trim pieces around the gauges to check?
I would assume you checked both glove boxes, the center console and any other storage compartment?  I had a similar thing with my 2020 and un-known to me my son had put a golf ball in my center console.  He likes to hide things on me and play tricks....
 Yes. This is clearly coming from around the gauge cluster area. It didn't make the noise for the first few days. Every time I turn something is clearly rolling around back there.
I worked as auto tech at car dealers for 12 years, we had a brand new Hyundai that had a noise under the seat, after stripping the seat and carpet, still something rolling around under where the seat is mounted, ended up cutting a hole in a enclosed brace/gusset under the seats, someone at the factory put a steel pinball in there before it was welded up, Hyundai had to buy the car back because we had to cut a structural part of the car out to find the noise and remove it.
Funny stuff right there.
Good lord I hope that's not the case lol. I didn't hear it for about the first 4-5 days
the trim piece above the cluster will pop straight up and give you access behind the cluster.
there is a panel on the far left side of the dash that pops off to give access to the fuse panel under there
once that's off you will see a couple of T15s that if removed will allow you to pop off the drive mode/headlight switch panel. after that I think there is another bolt and you can remove the speaker grill but the A pillar cover must come off first, remove the two small caps near where the handle connects and remove the two bolts, there is one last metal clip that is rather difficult to get off. use caution there as there's airbag components behind the pillar. once that's off the speaker grill can be removed. the speaker itself can also be removed once the grill is off, there's a cavity behind the speaker.
If you need to get in farther look up installation instructions for the Autostop eliminator (while you're at it, install one!) and you can see how to get the trim around the radio and the radio stack itself off.
that's as far as I've been into mine, but there are a few different areas to explore to try to find whatever is rattling. maybe a tech dropped a screw and couldn't find it anywhere, just got another one and kept on going. let us know if you ever find out what it is.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 1,769 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
