I have a 97 Chevy silverado with a three inch lift what are the torque specifications for the U bolts
if you have a 4x4 shop near you , they should be able to give you that information, or im sure you can find it on internet someone has posted it somewhere.
 i have factory specs on the same truck , but not for altered suspension ,on standard suspension it will be around 100 ftlb ,
