2021 sierra evolution
13xxx kilometres on it.
2 days ago the display was replaced due to freezing and screen going blank.
Today I brought it back due to misfiring, service esc and park brake.
Just got the call that it needs the lifters on the right bank.
What else is common???
Thanks
Welcome to the forum.
Just do some reading on this forum and you can find a lot of issues "some" owners have with their trucks. 😉
If you have a sliding rear window, keep an eye on it because a leak might be expected at some point.
But beyond that, the issues you’ve had don’t really mean you have a piece of junk that’s gonna break down constantly. Stuff happens. Vehicles are more complex than ever. I’m on a lot of groups and the same thing happens to all makes and models.
I have a 2019 GMC Sierra purchased in Jan 2020 and just 2 months ago the rear window decided to start leaking.  Rear window with slider has been replaced. Still waiting for the dealership to install new carpet in the rear after it sat on their lot for 2 weeks soaking up the rainwater.
Previous to that, the 3rd brake light had to be resealed within the first year.
Aside from those two leaks, I’ve had no issues.
I do use Premium fuel and full synthetic oil. I have just over 30k on the odometer today.
6.2 & 10 speed
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
