Got my '21 AT4 HD, but didn't get the trailer tpms sensors or camera.  The dealer told me I could get the sensors for $50, but when I went to lick the truck up they said the sensors would be $150 for two (I need 4)  I think I saw on this forum that someone found them online cheaper.  Anyone find sensors cheaper that do the temp also?  Did someone else find the camera cheaper?  I have $100 in GM rewards, but I hope I can find them cheaper.
Cheapest I found the camera was at ShopChevyparts for $356.  They have a new customer discount too.
Edited by TheeSpaniard3500hd
On 6/5/2021 at 8:32 PM, Major Tom said:
Check Ebay.  Many get the sensors when they buy a SUV/Truck off the dealers lot and don't need them.  I picked up four for $75.
One current item below:
4 OEM Tire Pressure Sensor TPMS for GMC Sierra 1500 2500 3500 HD Yukon XL 433MHz | eBay
I assume that these will work with the trailer for pressure and temperature?  I noticed that they are not the same model number and that the valve stems are rubber and not metal.
The link was just an example I found with a quick search looking for “GMC” and “tire pressure sensor”.  If you have a a part number you need, just search for that part number.  There is a very good chance you will find it.  The price is better than the GMC dealers, that’s the point I was trying to make.
I saw on another forum that other 433mhz sensors work.  Does anyone know if there is a way to test a third party sensor without having them installed in the tire?  Can I try to pair them without putting them in the tire?
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
