So i have an 04 silverado,  was doing some electrical work and i accidentally dropped a wire on the ground post and it sparked, next thing i know the truck wouldnt crank with the key unless i jumped the starter relay,  the blinkers stopped doing anything, not even the indicators on the dash would light up, but the hazards worked, the tachometer was going nuts, and the AC compressor will not turn on, replaced and flashed the PCM with a new one and the truck finallt cranks and tach is back to normal, but the AC and blinkers still dont work, ive checked all ac and turn signal related fuses and all are good, freon is full and properly charged, what gives, also installed a new multifunction switch for the blinkers and no luck, any suggestioms are greatly appreciated
Lesson learned i hope. Always disconnect the negative battery cable before you do any electrical work just for this reason.
Start by using a schematic and an Ohm meter and check where you have current and work your way to the dead spot.
Sorry about the bad news. Let's all take notice here about disconnecting the battery before servicing anything electric, I seldom do unless it's the battery I'm working on and I know better, I'm just too old school. lazy and stubborn. I never had no trouble like this on my '63 Galaxie, '64 Galaxie, '67 GTX, '71 Chevelle, '71 C-10, '73 C-10, '78 C-10, '38 S-15, '85 S-10 by gosh!
Some thing is shorted out or burned to the point the circuit is broken, it could be a bad ground; remember with any freaky  electric issue bad grounds are often the culprit. Keep us informed!
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
