Hi dears ,
i have a 2018 Yukon, and i just noticed the oil pressure is about 20 on idle (full stop) .
on accelerating the oil pressure go up to 50 and arround it.
please should i worry about it or this consider normal?
OD is 55k km .
Normal especially if its up to temp and running for a while.
Are you getting any messages on the dash like low oil or low oil pressure?  Check engine light?
8 minutes ago, Steve_rayan said:
Thanks newdude ,
the outside temperature is 100f now and no i don’t get any warring on the dashboard
Sounds like its working fine then.  100F outside so everything is hot so the oil temps are probably a touch higher than normal but still in a safe zone, hence the slight dip in hot engine oil pressure.
Edited by newdude
Thanks, I really appreciate your reply.
Please advise what is the normal operating range for the oil pressure.
and what is normal for the 100F and above weather?
also can you please be kind and explain the relation between the outside weather and the oil pressure readings.
Thanks in advance :)
The ambient temp causes the engine to heat up a little faster. It might cause the engine operating temp to read a little higher in some places like Iraq or Kuwait.  That’s the only relationship.   Once the engine is “heat soaked” it might read higher in some climates but just a few degrees.  U might or might not see the difference.  IMO.  But who am i
Edited by TxVet33
Me
Well, GM just has a minimum spec of 6 psi per 1000rpm.  So if your engine was say stuck idling at 1000rpm, 6psi is the bottom of the barrel.
Typical operation on these trucks, 20-30psi at idle, 38-42psi cruising.  40-50psi under 3500rpm acceleration.  Anything over 3500rpm the oil pump moves into the high pressure stage and the gauge can jump up to 60+psi.
  • Thanks 1
Good to know mine is 'normal' A bit over 30 hot idle, 38-40 cruising (55 mph 3.23 gear, stock tire) . 45-55 spirted under 3500 and pegs the gauge near red line.
If 0-20w is the issue. What is everyone running in their 5.3’s?   Mine in my ‘19 Yukon  doesn’t have a 30psi difference. Mine at most has a 10psi difference???  MIne idles at 550 rpm.  At speed mine reads 50psi.
We have an extreme weather, it’s reaching 55C and under direction sun is 65C
that is why most of the owners not using such oil .
however the local dealer keep using it .
Oil viscosity vs oil temperature
3 or cSt in viscosity will not show on a dash gauge.
Remember these trucks use the water cooling system to cool and heat the oil. Even if the water temperature is 10 C higher this results in but a 3 or 4 cSt change in viscosity. If you think you really need more viscosity protection find a suitable synthetic 0W20 or 5W20 with a HTHS of 3 cP or better.
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 644 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
