I am sorry after going through your site I am still unsure as to what I need to order to do what I want done. I have a 14 silverado wt crew cab that was an I04 with 4" screen, connectivity, xm  and back up camera. I bought an 8" screen, and a radio with xm that came out of the same truck, I06. I then bought an hmi that is an I06 but a 2.0. I know that I have to have the radio and hmi reprogrammed. But I do not want AA or apple junk, I just want to have handsfree calls, back up camera, radio and my cd player to work. I do not use pandora and such. I do not see the advantage of a 2.5, speed is not an issue for me. Nor can I find a 2.5 that shows that it will work in my truck. I do not know what programming to order other than vin. Please advise a middle aged person.  My part numbers are below. Please direct me.
Radio Module Interface
23176319    8" screen (had 4")
Radio. Module  13592804 I04  change to 13592804 with I06
CD Player 13590747
HMI 2.0   23428003  I04 change to  2.0  23443747 IO6
working on that. i am slow to understand so i hope they are patient with me.
  • Thanks 1
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 504 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
