I have an opportunity to purchase a 2002 Chevy 1500 Z71 Extended Cab with around 120K miles.  Been sitting for a few years so will need some work.  Before being parked the entire A/C system was replaced ($2K).  Brakes are sized up at the moment so if I purchase it I'd replace the breaks all the way around and possible the brake lines.  Has leather interior that still looks new inside, no rust on the body or any dents.  Original paint is faded and the clear coat is peeling.  Needs new tires as well and I'm sure will need a complete tune up.  New fuel pump was just replaced to make sure the truck started up and ran.  Is $2K too much for the truck in the condition it's in?
For $2,000 that sounds like a great deal for a rust free body and a engine that runs.
If you buy all the parts yourself and do the work yourself, it'll be well under $1,000 to get all new calipers, rotors and pads. "Tune up" parts are cheap too, plugs and wires, new fuel filter, oil change and away you go.
Well I went by to take a quick look at it and it was in worse shape than I was told. There was a rust spot on top of the cab and the dash was all cracked. Said he would take $1000 for it since he wasn’t aware of the rust and dash.
You can get a new dash pad, do an internet search...otherwise if you need a truck for the winter this is worth the 1k.
Even still that is a steal.  120k on a 5.3 is nothing.  The only problem might be the fuel and seals dried up, which can be time consuming especially the rear main.  Again id be over that for 1k all day long.
Snapped a few pics of the truck.
Well pics didn't work.  Let me figure this out.
Edited by PearlWhiteGT
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
