Hey everyone, my side-view mirror was side swiped on the way to work. The glass popped out but I popped it back in and the motor seems to work fine with the only issue being the glass is broken. Is it possible to replace the mirror without having to replace the whole assembly?
Welcome to the site.
Answer is yes, but you did not say which model of truck you have. This is an example from Amazon, for a base model truck.
For Chevy Silverado 1500 Mirror Glass 2014 15 16 17 2018 Passenger Side | Heated | w/Backing Plate | All Cab Types | Convex Glass Type | GM1325145 | 22919746
Price: $39.57
    flyclt
    flyclt
  • Who's Online   5 Members, 0 Anonymous, 592 Guests (See full list)
