Hello, I just removed my jump seat console for a full console, with wireless charging. It is on my 2020 silverado 2500HD. Everything looks and works great, except for the remotes. My display says to service the remote. And the door unlock buttons don't work now. Any ideas would be greatly appreciated.
there is a remote detection module in console.   you should have plugged it in. you can try to re-initialize the remotes
Ok thanks. I plugged in the big cable under the passenger seat, but the was another smaller connection that I didn't plug in to anything. Also the console is brand new. Do you think it didn't come with one and I need to install the one out of my old one? Thanks!
it might be this module, do you have it?
Turns out the new console did not have the anti theft module in it. So I am going to put the one from my middle seat... thanks!!
What did you do with your old one?  Was it one that the center console opened on?
It was a console that turned up to a seat.. I really didn't like it. Sold it locally after I removed it, they really swap out easy.. watched a video on YouTube and boom done.. very happy with the full console
  • 7 months later...
Did you add the usb data ports to your center console?
No I didn't, the ones under the radio and heat control were not in the way so just continue to use those....
Where did you get the new full console from?
jbw-garage
On ebay.... very positive experience....he sells all kinds of brand new consoles
I didn't get a full console, I just bought the same one except that it had the center compartment that opened from an online GM dealer, the original WT one didn't open at all.  I didn't want the full one as I still wanted to use the center seat.  Mine is a regular cab so occassionally someone sits in the middle
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,286 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
