My rear window continues to leak after the dealer said they fixed it. I don't believe they actually touched it, there is 0 evidence of them doing anything back there (unless the technician was 100% perfectly meticulous, doubt it, most techs are hacks).
anyway, is there a new or updated TSB to address the leaky window?
thanks
My truck is at the GMC dealership now getting the rear window resealed, both corners were leaking. They said there was a new TSB on it. That was on 12/09/2021.
My rear window was leaking when it had about 20,000 miles.  The dealership followed the TSB and sealed it. It is about a year later and I just noticed today that it is leaking again. I haven't seen another TSB and it appears that they removed the old one. I'm afraid to bring mine back because they damaged my headliner last time and had to remove and replace my front windshield to get a new headliner in. At least they had loaners at that time.
I just noticed my rear window leaking the other day I thought I was seeing things. This is the second GMC that has done this.  Good thing it stays in the garage.  Most of these guys are so young doing the repairs, they lack attention to detail but that will come with age!
Mine is in as I type this for the second time and getting a new rear window installed per the TSB. The dealer service advisor told me that the new glass has a new part number and appears different from the old window; something about the curve at the top of the window? The TSB states: "If the vehicle underwent this bulletin repair, was released to the customer and later returned for the same concern, replace the rear sliding window. Refer to Rear Sliding Window Replacement in SI, AND ensure that during application of the urethane to the new window, that the urethane covers the complete length of the top encapsulation of the window." https://static.nhtsa.gov/odi/tsbs/2020/MC-10173388-9999.pdf
They also did a DEF tank inspection and ECM update for the DEF heater under a recall. He said I was lucky, they have two trucks that have been waiting for a new DEF tank for ~6 weeks. I don't have the recall information yet as the truck is still at the dealer.
I hope this is the final fix for the window!
    RichardRS
    RichardRS
  • Who's Online   4 Members, 0 Anonymous, 843 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
