2019 5.3L - put a K & N CAI on it and a cat back.  Will an enhanced MAF sensor gain air flow / HP?
I searched for this topic and didn't find it.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   3 Members, 0 Anonymous, 5,002 Guests (See full list)
