1. Window sills
I have a silver Silverado, and I have removed almost all chrome.  I'd like to remove/change the chrome window sills. The pic of the black truck with red arrows here shows the part to which I'm referring (not my truck in pic).  Anyone know the part number?  Anyone have any black ones?  I know I could vinyl wrap or Plastidip, but it just seems small enough to get an entirely new part.
2. Front grill
Same questions.  The pic of the red truck shows the chrome grill fins (where Z71 logo is; again, not my truck in pic).  I'd like these to be black.  I can't find the overlays in black.  Anyone know a part number for the black version?
3. Mustache
The instant I got my truck, I Plastidipped the hideous chrome mustache on the middle bottom of the bumper.  It is also shown in the pic of the red truck.  I am referring to the chrome piece directly below the center of the painted part of the bumper.  Is there a way to buy an OEM or OEM-style black version of this?  Perhaps just the mustache or maybe the entire bottom valence thing?  Anyone got any part numbers?
4. USB ports under radio
Off topic, but this seems common.  One of the two USB ports under my radio (see picture with yellow circle) has gone out.  I checked the fuse, and it's fine.  I can't find the precise part number, and I'm asking here rather than calling dealer.  Anyone know?
Edited by ~~AAJakeleg
For the Mustache, if you can find the Midnight Edition part, it’s black. That’s the only package that came with a black one instead of chrome.
I don’t know the part number.
5 hours ago, ~~AAJakeleg said:
Bump
Have a look here?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
