My truck will throw the P129D every couple of days when I start my truck, code never comes up driving. I’ve installed a new fuel pump control module, and a new battery, and the issue still persists. Anyone else had this issue before? It’s got me confused
Edited by greenoliver1
Added to post
On 10/19/2021 at 8:53 AM, silveradosid said:
watch this video
i watched the whole thing, but the problem is in Eric’s case the code was staying no matter what, if I clear mine it goes away for a few days then randomly comes back when I start my truck. If mine was constantly on I could easily do the same procedure for finding the break, but I checked my whole harness as best as I could and didn’t see any chafes, and I opened the harness in a few spots and tugged the wire hoping it was broken and would come out, but it was nice and tight in there
it still could be the problem, it may not be corroded all the way threw and the plastic wire insulation will be strong enough that you cant pull it apart. does moisture or rainy days seem to effect when the light comes on
Hello. Did you find the cause to the problem?
Thanks
My 2016 gmc sierra just stared doind the same thing. Same code. Did you solved theis problem?
    • I never understood the hate for the column shifter. The console shifter just gets in the way, takes up prime cargo space and in my wife's Jeep, the dog constantly bumps the console shifter into neutral!    Best choice ever to just make it a column shifter across the lineup and be done with it.    (Bonus: Makes swapping from a 5 seater to a six seater far easier)
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
