I have a 1995 z71 4x4 1500 5.7engine and I don't know if both wheels are spinning at the same time in 2high/ 2wheel drive???
You can test that pretty easy. Get the ground really wet or hit a dirt road. Do a power brake stand and see if both wheels start spinning. If you get a one tire fire then it's an open diff on the rear end.
Obviously this would be for those specific reasons that only 1 tire gets all the power. With normal operation the power will be split 50/50 when going straight down the road.
