Looking for some help on my wife’s 2017 Chevy Silverado ..it has 48,000 miles odd.
She said she was driving along going around a corner slow and the traction light came on in the vehicle quit
She said it restarted right up it went a little bit for a while.
The second time I was driving the vehicle backing out of a spot the steering wheel got tight the engine stalled like I turn the key off and on my dash it was saying to roll my window up and down I did this and then the vehicle started right back up !!
Two days later my son was driving the truck pulling into a parking lot going slow into a spot he told me the wheel got tight couldn’t turn the wheel in the vehicle died out again and then he said the same thing he noticed on the dash it was saying to roll the window up and down on the drivers door.
This vehicle is still under a factory warranty I’ve been reading reviews and it doesn’t seem like they really know what’s going on I’m hoping maybe somebody on this site can enlighten me give me an idea on this type of problem or had this type of problem and what was the outcome, Seemingly it’s only done this at a real slow speed ,I’m going to schedule an appointment At the dealership and hoping they found out what these issues are ,I know intermittent problems can be a real pain in the butt could be anything from a bad ground,or possibly wires shorting out , again anybody who’s had any of the symptoms I’d really like to know if they ever found out what was causing it thanks again Scott
My 1st thought is "Bad Ground". Many issues pop up on the forum about this plus many Youtube videos. Since it's under warranty, let the dealer check it out & mention to him "cleaning grounds"
Good luck & keep us posted...
Thanks for the info much appreciated I check the vehicle out today and found my positive cable was very loose I guess when I bought the vehicle they forgot to tighten it I’m hoping this cures the problem time will tell I will keep you posted I like to know when something gets fixed when people reach out to help thanks again Scott
If it doesn’t pan out I’ll drop it off at the dealer thanks again
