I know this topic comes up often and there's lots of opinions on it. So I appreciate your patience and any insight ya'll have.
I bought my 2016 Sierra Denali used in 2018. It had high mileage (83k) but was extremely clean and a seemingly good deal. I occasionally haul a large enclosed trailer. I've also hauled a bumper pull RV across country for family trips. While it hauled the trailers amazingly well I've been less than impressed with the day to day ride. It does not handle bumps or rough roads anywhere close to what I had imagined a "denali" truck would. It's borderline embarrassing. I bought it in the winter and honestly didn't notice until the Spring of 2019.
Unhappy with the ride, I've considered replacing the wheels with a smaller 18 inch wheel so I can get more rubber on the sidewalls in hopes of smoothing things out. I've also considered replacing the magneride shocks with a small aftermarket lift with shocks/leveling etc. (like a leveling kit or 3.5inch lift kit?)
However, today my truck was in for service (tranny work - but I won't go there 😂)  and a guy I trust pointed out that one of my rear shocks had failed and needs replacing. He is adamant that replacing the shock may solve a lot the overall feel and ride issues that I've been complaining about and that going with an aftermarket lift/shock/tire/wheel replacement isn't the solution.
My question - has anyone owned their truck for a period of time, replaced their magneride shocks with OEM factory replacements and seen an improvement worth the bill? At over $500 per shock, It's going to be expensive.
Or has anyone replaced their magneride system with an aftermarket brand and seen an improvement worth while? (meaning lift kit/leveling kit/shocks/wheels etc)
I'm guessing to replace all four shocks with OEM equipment will run me close to $2,500.00 with labor. And I'm guessing an aftermarket package along with new wheels will be close to the same?
Any insight or help would be greatly appreciated!
I have the same year, and engine so I already know exactly what type of "transmission" issues you're having... fun stuff with the 8speeds!
Can't speak to the shocks and that issue but I have a set of 18" Denali wheels when you're ready 🙂
Edited by STurner15
I also have a 2016 but it's lifted and running 35's but...
I replaced my front shocks myself last January because both failed and were locked extended.  I found replacement shocks for closer to $650 for the pair. Truck drives like it should now.  I have noticed that the rear rides much better with 100-200 lbs in the bed and  I'd rather have a more firm ride rather then a squishy rolling ride. My rear shocks are still original (knock on wood now).
There are several videos showing how to do it and the connector is a PIA to change if you change the pins in the connector like most show.  I ended up cutting original shock wires and soldering that original connector pig tail to the new wires.
Is it worth it?  That's really up to you.  I didn't want to give that up quite yet but if they don't last I may quickly change my mind.
I can't speak to deleting the magnetic ride system, and I have yet to replace the magnaride shocks on my Denali...but I replaced them on an XTS at 60K miles and the difference was night and day.  The ride was not horrible yet on the old shocks, but the new shocks were well worth the money to replace.
There's some discussion around Magnetic ride on GM vehicles and from what I've read & experienced is that they simply don't last much past 60K miles or so.  Even if they don't fail immediately at that mileage, the ride quality dissipates quickly...
If your current shock(s) have actually failed or frozen up, you will be amazed at the improvement new magnaride shocks will have.  Considering you purchased the truck @ 83K, you probably have yet to experience the magnetic ride system to its fullest.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
