One of your O2 sensors is probably going bad.
If not that then somehow you have messed up your trucks tune causing the AFR to be funky
Copied from the net:
P219A Bank 1 Air/Fuel Ratio Imbalance - OBD-Codes.com
When a code P219A is stored, it means that the power train control module (PCM) has detected an air to fuel ratio imbalance for the bank of the engine which contains the number one cylinder. In order to monitor the air to fuel ratio for each engine bank, the PCM uses data input from heated exhaust oxygen sensors (sometimes called air fuel sensors).
I have a broken exhaust bolt on that side (one on the other side too) and wondering if this is the cause. I also have the AFM/DOD tuned out of the ECM but nothing else was messed with…
On 12/2/2021 at 5:18 PM, shakenfake said:
Yes that would possible have an effect. Time to get it fixed
20*F here
not looking forward to doing that
she can drive the BMW for a wile…
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 7,181 Guests (See full list)
