I would like to add power folding towing mirrors to my 2021 Silverado. I currently have the towing mirror with extension capabilities but it is a pain having to manyally fold the driver side when pulling into my garage.  The dealer has informed me that GM has not manufactured anything other than the standard mirror to date.  Has anyone got a line on an aftermarket product?  Thanks.
Not sure what the dealer person is smoking, if they don't know GM has power folding tow mirrors available on '21 1500's.
21 1500 factory power fold trailering mirrors availability depends on trim.
The factory order codes for '21 1500-- fwiw --
Yours must be -
DPO         Mirrors, outside power-adjustable vertical trailering with heated upper glass, lower convex mirrors, integrated turn signals, clearance lamps and auxiliary lighting; manual folding/extending
available on higher trims (Silverado LTZ and HC,  Sierra SLT, AT4 and Denali)
DQS         Mirrors, outside power-adjustable vertical trailering with heated upper glass, lower convex mirrors, turn signal indicators, puddle lamps, perimeter lighting, auxiliary lighting and memory; power folding/ manual extending
Side note -- on the HD's power extend / power fold is standard on higher trims.
Lower HD trims get power fold / manual extend or manual fold / manual extend.
Small mirrors are an option on lower trim HD's
If you do not currently have the power fold option, you will have to change out the harness in the door as well as the switch in the door to add that feature. The 2016 Silverado I had did not come with those features either. It took about 3-4 hours to swap the harness, switch and mount the tow mirrors. Pgamboa may have, or can get, everything you need to get you where you want to be. Shoot him a PM. He is a great guy and will help out with any questions you may have.
    250.3k
    Head Scratcher
    Head Scratcher
  • Who's Online   4 Members, 0 Anonymous, 402 Guests (See full list)
