I have a 2020 1500 3.0 duramax that has run on the warm side of 210 degrees since new, at 30,000 miles it overheats regularly.
 I have taken it in to the dealership for service every 5,000 miles and told them about the overheating, their answer is these trucks run warmer because of the DEF system and they said they could not get it to overheat. Any ideas or help would be much appreciated
My truck runs a little warmer when it Regens but that's expected. Never had an issue with overheating tho. The DPF is what heats up at Regen the DEF is sprayed into the DPF to remove particulate buildup. Do you get a check engine light or overheating warning on the dash?
Define overheating.
Like it gets to 240-250 degrees and shuts the truck down type warm?
Just a FYI, the gas engines will get to 220-230 on a normal basis if they are put under heavy load for long enough and for sure in the summer. That is completely normal for the stock temp thermostat and factory fan settings.
Thank you. It it does that also, but I drive 23 miles to work, last week it was 74 degrees and 3 days when I got home it has went way up and blowing coolant out. I have to add coolant about once a month. The dealership says this in normal
  • 4 weeks later...
That's definitely not normal.
Issue with the fancy coolant distribution valve perhaps?
Is it a service advisor you're talking to, or have you escalated up the chain?
Back of the OM has the steps GM suggests for 'escalation'.
Be pleasant, keep records.
Fwiw, my LM2 is just over 16,000 miles.
I've only added a little to mine. It's not on ignore, I do check from time to time.
It does the thing where the gauge runs a little higher before the distribution valve settles in.
It's never 'blown coolant'.
Probably get more reads/responses in the sierra/silverado troubleshooting section or engines section instead of here in 'future speculation'
Edited by redwngr
The 6.6's get hot like this when the head gasket blows too. Any black flakes of carbon floating around the expansion tank?
  • 1 month later...
I had a 2020 Duramax and it ran the temp up all of the time. Near 3/4 on the gauge. Never had to add coolant.
My 2021 does not do this, it rarely goes above half and i'm ok with that !
From my learning on these trucks, the 2020 will go up and back down on temp. The key is that it goes back down...
If you are having to add coolant, there is an issue. If it's just a temp gauge getting higher than you like to see, that is unfortunately the way most of the 2020 trucks are.
4 hours ago, Mike Bullock said:
Service advisor
It's been over 2 months since your December post.
Any updates?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
