Hey folks. New to the forum and have learned a lot - thanks to everyone who takes the time to help others out.
I have a 2021 Silverado 3500 SRW long box crew cab LT (might be LTZ). Anyway, I took the tailgate off this fall so I could put my Northern Lite camper in the box for hunting season. Now that hunting is over, I took the camper off and re-installed the tailgate. Problem is, when I press the button to open the tailgate it lowers about 1 foot or so and then stops and it appears to get stuck. I can close it back up fine, but cannot get the tailgate to drop more than a foot before it gets stuck. Do any of you experts have any insight on how to solve this problem?
Truck is due for its first oil change soon, so was planning on just taking it to the dealer and getting them to fix it. But I like to fix stuff myself when possible. Any ideas? Thanks for any help you can provide!
Jason
Edited by TallMoose
  • TallMoose changed the title to 2021 Silverado Tailgate only lowers about a foot then stops/gets stuck - any ideas?
First, wrong subforum.  This is for the half-ton trucks.
Secondly, have you checked to make sure the bushing on the right side hinge isn't sliding out?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,301 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
