Installing Hardwired Dash Camera In 2019 Yukon, Needing Constant & Switched Power Circuits
I have a dash camera already installed 2 weeks ago.  Bought some of those fuse taps and found that the new GMs use funky fuses, so I had to wait and order the correct style.  They've finally arrived, and I'm ready to hardwire this dash camera.  What I need is 1 constant power circuit for normal camera operation and 1 switched power circuit for parking mode.  It's easy to check circuits with a volt meter to find out which are dead with the key off and which aren't.  However, I have no clue if power to some circuits times out on a delay, such as the radio circuit.  Considering the doors are open when I'm testing these circuits, I want to be absolutely certain which circuits I tap into.  Also I'm preferring to tap into non-crucial circuits in the event of a camera malfunction.  I'd rather be without heated seats than BCM power, after all!  Thanks.
Why not use wire taps into the back of your rear view mirror? You can buy the wire taps off eBay fairly cheap and Google or YouTube to see which wire to use.
Edited by cs15dah
Check GM upfitter website for the SEO pin locations in the inside og the cab. There should be spare pins for RAP and constant power.
I'm not a fan of those wire tap things, they are garbage as far as I am concerned.  Also there is more to installing it than just a wire that you can splice into rearview mirror wires.  There's also a circuit box I believe to differentiate the constant and switched power circuits.  I have everything nicely organized and tucked, zip tied already behind the driver side cab fuse access door.  I have never used a fuse tap before but I hear they are decent.  They use 2 fuses so your original circuit remains with the original amperage fuse and then your new circuit, this case the camera, will receive a 5 amp fuse.
Where are these pins you speak of?  And this applies to all of the SUVs, not just the Police PPV and SSV Tahoes?  I know I can move a fuse in the panel to switch from switched accessory outlets to constant power, but I prefer to leave the accessory outlets as switched power.  There's a square fuse and 3 pins, you move it one direction or the other to make contact with 1 set of 2 pins or the other set.  But I can't tap that style fuse with these fuse taps anyway.  It wouldn't work, unless you're talking about something else that I am not aware of.
There should be a separate box under the dash that has the upfitter pins for all aux wiring requirements. I know on the GMT900 series it is by the brake pedal. I do not know where it is in the other models but the GMUPFITTER.com website has all the wiring information for all GM trucks including the Yulon. The manuals are several hundred pages long and have all the info you need, you just have to spend the time to digest the information and find the box with the connectors. The description of the pinouts is in the manuals in the link i provided.
I have a large box near the brake pedal that has a cover with 3 tabs that hold it on.  This was where my brake controller wire harness plugged into.  But as far as auxiliary power feeds I don't believe they provide those with civilian vehicles.  That would likely be PPV or SSV only.  The GM Upfitter website has very little information available for my vehicle.  I'd imagine if they provided it for all civilian vehicles at some point they eliminated it to cut costs.
Are there unused taps in that box? If so, test them for power and note their state (RAP or constant and use them for your dash cam. That box on the 2010 I have, which is a base model, had all the wiring in there for my dashcam and any aux wiring I might need. GMupfitters showed me which to use for my needs. They may have cut those feeds in later years but I doubt it as it would be too expensive to make multiple harnesses. I know is was still on the pickups of your model year.
I know what you're talking about.  In the driver side footwell the black box has an extra unused plug slot that has the ground, constant power, and switched power feeds you are describing.  I read in another thread about that yesterday morning.  You can either attempt to locate the plug or some users used teeny tiny spade connectors are the pins are tiny.  I didn't go that route.
For the dash camera's switched power I used a fuse tap on the RPO power fuse in the driver's side dash fuse box.  And for the camera's constant power I used a spade terminal plugging directly into the constant voltage feed beside the large fuse that can be moved over for the interior accessory outlets.  I of course added an in-line fuse for this circuit as well so everything is fuse protected.  Works so far, haven't driven anywhere with it yet except around the block.  This should give the camera the ability to record in parking mode as well with the +12 volt constant power feed.
https://www.gm-trucks.com/forums/topic/155775-2014-rap-retained-accessory-power/
Here's the power feeds you are referring to.  Pretty neat they are still included, but from what I read, if you want to do it "right" the actual plug that fits this particular unused slot may be difficult to source.
Not the wire taps that "splice" into the factory wiring, but push pins that slide into the connector along the bare wire that's already exposed.  Here's an example, and they work really well and really easy:  https://blendmount.com/mirrortap
I haven't seen taps like that before other than for electrical diagnostics such as backprobing connectors.  That doesn't seem like a "permanent" solution in my mind.  If it works, it works.  I just prefer soldering 99% of the time.  They also have those watertight shrink wrap wire connectors that have solder in them that only requires a heat gun to melt.  I'd also rate that as acceptable although I have not used one personally.  I also understand that mechanics in a shop will never be as precise or a-n-a-l as I am with my own vehicle, as soldering definitely adds minutes to any job.
Edited by BlaineBug
Regardless my camera install has worked flawless now for almost 2 weeks, both with ignition only power and constant power for parking monitoring.  I'm satisfied and have a 1,100 mile road trip coming up in just a few days which is great timing for a dash camera.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 555 Guests (See full list)
    • Atlas,   Then following your logic we can't believe any story that the MSM produces? I mean it's documented they heavily donate to Democrat candidates. Vote Democrat in high percentages. Many MSM talents are married to Democrat politicians, Gov. employees. That goes for on-air and off, personalities and reporters. So they would all be biased and nothing they produce is to be believed in your mind?   Again the article simply was about ways AI can be used for pricing products. Nothing discounted current situations as a factor.    Again keep looking through your left/right lenses. I don't live my life that way.   And as a heads up this thread will be cleaned up again as much of this is off topic and is receiving
    • Yes, and only a couple years before delivery. 🙄
    • So you're saying toss the baby out with the bathwater? @txab posted article was her take on how AI can be used to manipulate pricing as it already does and has been rebuked by the judiciasry in housing. How AI can be and is used to maximize refinery or even Amazon operations all of which are true but because she is who she is; that makes what she says about what is true, false? Is that something akin to Pre-justice aka prejudice?    Look, I'm first in line to approach all information with caution just because we live in a world where people like to lie about someone or something with such a straight face and in such volume that it makes digging to the truth wearisome. Meaning I understand the skepticisms but if I were to toss out everything a person is for a view they hold then my pool of people to draw wisdom from would be non-existent and I'd be forced to reinvent the wheel daily. Not practical.    "Be innocent as a dove but as cautious as a serpent."    Test each word. Every good lie is part truth or no one would believe it. Find the truth in it and reject what isn't.    On this one, AI is being used to do what has been done by hand for hundreds of years already but at such speed, the point of a computer, that it is more easily monetized. This one wasn't that hard a lift.    I wrote a few formulas in a Lotus 123 program decades ago, a series of linked Macros actually, that allowed a daily inventory to be turned into a running P&L and production plan. Something that took three departments a week to assemble now took the time it takes to input the 'daily changes' in inventory. Later that was ungraded to the more powerful Excel program an and integrated with bar code scanning, inventory to supply was done once per shift. It had a huge impact on production scheduling, Seamless interruption flexibility, inventory error reduction, raw materials cost effective utilization and scrap reduction. Huge improvement in the bottom line. I spent months on that and AI could have done it in minutes. So yes, it not only can be used, they would be foolish to not try. The legality, ethics and morality are not the domain of AI. Humans need to keep a reign on it.
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
