Has anyone here purchased and used HP tuners for disabling DFM?  There are some YT videos on it, but they all seem to be for pre 2019 models.  The HP Tuners website lists the 19-21 5.3 as a programmable option, but doesn't say what can be programmed.  I am going to reach out to HP Tuners when I get a chance, but figured I would check to see if anyone of you have done this.
You have to send the ECU to HPTuners to be permanently unlocked before any tuning can be done. But once that is done you can turn in or off just about every function in the ecu.
Edited by BRPRacer
Thanks BRPRacer!  I was doing some reading through their forums, and it appears that once unlocked, the dealer can no longer reflash the ECU.  I'm not sure that is a route I want to take while under warranty.  Maybe the Pulsar LT is a better option for me.  I have a Range AFM/DFM disabler, but I have kicked it loose a couple of times and the case is separating from the plug.  I want something that is out of the way.  For the price of the Range I have broken, buying another one already puts me in Pulsar territory and I get more functionality.  I think that is probably my best route.
^^^^^WITH ABOVE STATEMENT^^^^^^
Do people read for comprehension on this site?  He already stated he had the Range device! He also stated that he has hit it a few times with his leg getting in and out of the vehicle.
 unreal bill hader GIF by Saturday Night Live
Edited by TNTSilverado
  • Haha 1
I would absolutely recommend the Pulsar LT. I adjusted my throttle response, increased the speed limiter, adjusted speedo for tire size and disabled DFM on my 6.2. Drives like it should have from the factory. If you use the chat function on Realtruck.com, they'll give you a better price than what's listed and they price match. I got mine for around $430 before tax.
  • 3 weeks later...
Thanks Nick.  I ended up ordering and installing the Pulsar a couple of weeks ago.  Wow, what a difference!  All I can say now is that I am suspect that the AFM/DFM disabler was ever really working.  (at least after I kicked it loose the first time). This thing definitely made it run like it should have from the factory.  I didn't even bother adjusting the throttle response.  I disabled auto stop/start, disabled DFM, and bumped the speed limiter a bit.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 592 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
