Truck ran but stalled. No ignition pulse. No 5 volt reference to PCM. No codes with cheap scanner. Has fuel pump pressure
New parts:
Gas lines and gas filter
Crankshaft sensor
Camshaft sensor
PCM with VIN coded
Master window switch
A relay
Ignition switch
Tried relearn procedure
What could be the problem?
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
