Looking for guidance/knowledge or just best guess!  2015 Chevy High Country 6.2L with 65,000 miles.  When the truck goes from V4 to V8 it makes a single "chirp" noise.  EVERY TIME it shifts from V4 to V8 I hear it, making me crazy.  Dealer said "I hear it, but we don't know what it is.  Maybe a relay snap."
Any ideas?  Thanks.
