The tires on my 2019 GMC Sierra 1500 SLT are Bridgestone Alenza A/S, 275/50R22. I'm wondering what other sizes I can use on the 22" rims. Thank you.
285/45/22
If you want your speedo to stay the same without having to buy something like the Pulsar LT to correct tire size, you need the stock size or a 33" diameter tire.
285/50R22 is 33.2" and would be within 1/2mph of stock, but options are more limited than stock.
33x12.5R22 is an option as well.
Speedo will read about 1.5mph faster than actual vehicle speed with 285/45R22 at 60mph as its almost an inch smaller than stock diameter.
Edited by newdude
The most AT options are the 285/45/22.  Our dealer has had several T1 trucks on the lot in the past with that size.  What I can't understand is, the T1 22" size is a 275/5/22 and the X31 and HC 4X4 comes with 275/50/22 highway tires and not AT tires so why isn't an AT tire made in that size for the 4X4's.
    250.3k
    Griffin Donovan
    Griffin Donovan
  • Who's Online   2 Members, 0 Anonymous, 503 Guests (See full list)
