Fuel gauge and Auto 4wd "howl" noise
Two issues, and I'd like to get your thoughts:
1) I've had my 2002 Tahoe Z71 for a little of a year. In that time, the fuel guage has dropped off from about a 1/2 tank to dead empty (low fuel light came on) in the snap of a finger. This has occurred 3 times. Restarting the vehicle won't reset the guage, only filling the tank will. Since it has a 1/2 tank, even though the gauge doesn't read that, it only takes about 12 gallons or so. The dealer looked at it yesterday and said because it's not doing it now, he can't fix it. But he is willing to drop the tank and make sure everything is tight and stuff. Question: Anyone else have this problem? Would you have the dealer pull the tank down and inspect? My thought is that I should get this on the record before the warranty runs out.
2) We all know that our 4wd systems howl a bit when enagaged in AUTO mode. Just a low sounding groan on the highway and when turning. We consider it normal. I had the dealer change out the axles and transfer case fluids a few weeks ago, and I had them listen to the noise. They said it's not normal and want to keep the truck overnight, pull all the covers off the axles, transfer case, etc, and check all lash toleranaces, etc, etc. Question: Would you have them go through all this even though it seems fine and has been deemed normal by many others? Seems I should as it's under warranty, and maybe they'll find something.
I basically just hate to leave my truck there for the day or two they'll need to get both done.
Thoughts? Thanks.
Can't help you on point #1, though if your dealer is willing to drop the tank to inspect, LET HIM. At least it's documented for warranty.
My 2000 has NEVER made a howl or groan noise, especially in AUTO. If I push the 4WD button and drive on snowy gravel roads, I can detect a slight whine, but I would consider that normal. Again, if Mr. Dealer is willing to verify this by inspection, let him.
I'm sure they'll give you a loaner car of some sort while they work on yours. In 2001, I had to take my truck in for the airbag recalibration recall. They were quite busy and all they had to drive was a Cadillac DeVille demo.
I "reluctantly" agreed to spend the afternoon driving around in that thing.
Boo Hoo. :cheers:
Thanks guys. I guess I'll let him get into it. The noise it makes in AUTO isn't really loud, but with the radio off, if you listen, if groans a bit. Well, I'll let them take care of it then. I always thought it was considered normal.
thanks
i noticed that the auto 4wd was getting nosier as time went on. i changed the front diff fluid and it that made it quiet again. the fluid looked terrible too, so i could understand why - but that was at 85k...
No howl here either. And the day after a 30K mi changeout of the front diff fluid I accidently left it in Auto in fine weather and drove over a 100mi at speeds up to 80 - never once heard anything different than in 2wd. But if I would have had to turn full lock I would have felt it.
Thanks again. Now what furstrates me is that I just paid to have the axles and tranfer case flushed and they'll have to drain them and refill as part of the inspection. Anyone ever heard of them issuing a credit/refund?
:cheers: My fuel gauge drops off for full or whatever to empty at a stand still. It does go to the correct reading when i start moving again. It acts funny sometimes. Someone suggested on the port that some brands of gas have more sulfur than others and its hard on the sending unit. I dont know if this actually is the case but just some food for thought. Let the deal look at it and tell me what he finds out so I can have an idea myself.
As far as the 4WD goes, no noise or anything. Unless I turn sharp all the way to the right or left I get a moan. But my bro in laws burb does that also and its brand new. I think its cause of the sharp angle of the cv joints. But driving foward and regular driving is fine. I can feel a difference in the steering wheel cause its pulling at the front now. But thats it. :cool:
If the GM dealer did the service, and they want to inspect under warranty, make them pay for it.
The fuel guage is a problem with the sending unit. It happened on my 03 Hoe. The dealer replaced the whole fuel pump and since then everything has been just fine. In fact, the current pump is now whisper quiet. It was all under warranty and didn't cost me a nickel.
I had my Tahoe at Lake Tahoe for xmas. Most people had chains, I just used 4Hi to get up the mountain. The only groan that I got was in 4hi making a turn and it was mild. It never groaned in Auto.
They will pay for the refill when they check it out, I'm just thinking that since I did the maintenance so recently, and they have to drain it all over again, I should be due a refund or at least we split it. It's not like it's been 10000 miles since the service, it was like 200! And it made the noise all along. If I brought it in before I had the axle service done, they would have had to drain it and refill it, not costing me anything. I spoke to the dealer though, and he said they wouldn't ave touched the rear, so I would have still had to have that done. They'll try to work something out. I won't make too bug a deal about it, just bummed that I spent $220 to have both axles and the xfer case done, when some of them need to be drained to be checked already.
In the future I strongly recommend you service the axles and transfer yourself. You'll need 5 quarts of gear oil and 3 quarts of AC Delco AutoTrak II transfer case fluid.
Your total cost in oil about $48.
To drain/refill my axles and transfer case takes about 30 minutes of my time.
I own a 02 Yukon XL and over the past 6 mo I too have developed the "drop off" gage syndrome. It shows up when I get down in the 1/4 to 1/2 range of the tank and a fill-up always fixes.
Recently, I noticed the fuel pump was making a louder than normal whine. A mechanic said it was normal and that they "all" did that. (Hmm, sounds a lot like the piston slap story. :thumbs: )
I took the truck in for service and amazingly they agreed and replaced the Pump and sending unit. So far, So good. :thumbs:
Definitely a job for the garage.
#2
I took my truck in 5 mo ago for a problem with the posi rearend (sticking on turn after driving straight for xx miles) I couldn't believe that OIL would take care of the problem, but viola', its perfect again. ( of course $85 later).
Now I hear/feel the same on the 4x4 when engaged. So could it be a repeat on the front transaxel?? Only issue is, no where I've found in the maintenance manual that you have to change tran fluids under 20k miles. Yet, I'm a believer now. :thumbs:
This is probably a DIYer if your so inclined.
2002 Yukon XL 2500
4x4, 6L, 4.10 R
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 517 Guests (See full list)
