When did GM get rid of the Cold Air Intake?  I was finally going to redeem my GM rewards points, and it no longer appears on the accessories website.  If I have the part number, can I order through the dealership parts department using my rewards points?
Probably like many other items, can't be sourced because of the manufacturer's inability to produce due to the global supply issues.  Good friend has door and window business and his manufacturer (WeatherShield) told him this week they cannot supply windows anymore because they can't get the vinyl materials to build them..
Edited by elcamino
I found the same some time ago when I was going to upgrade with the OEM Accessory CAI. It can still be found every now and then on ebay but I haven't found a price I like yet. They do however offer the upgraded OEM air filter but I have taken a pass on that.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 6,762 Guests (See full list)
