Anyone know what size socket I need to remove my Fuel Rage wheels. They are 20x9. I wanted the dealership to rotate them when I went for an oil change, but they didn’t have a socket to fit. The tech said I needed a 19mm thin walled deep socket. I ordered one from Amazon and it’s too big. The place I ordered wheels from is closed so I’m trying to get an answer before Monday.
They are open faced lugs so I don’t believe so.
I needed a 19mm thin wall deep socket for my recessed lugs. Just wanted to give an update.
Can you take a picture of the lugs?
**The hub cover is still on. **
Edited by BlancoSilverado
** added more info**
Sorry for the delay, I needed a 19mm thin wall deep socket to get the lugs off. I had forgotten to take cover off for the pic, but I got the right socket from O’reilly’s.
